what i thought was clipping wasnt? ..
reclessantics
SC
So i have an old autotech amp on an old jl 12 sub.
when i turn the amp up (just to set the gains and what not) it sounds pretty good, but i thought it was clipping. (the whole system would stop playing for a split second. so i went up to a local audio place, and one of the guys that ive been gettin to know came out and took a look/listen, and said na it wasn't clipping. he said i did a good job of setting the levels, and that it was just the cd skipping... lol yeah lammeee so i guess i should just upgrade my cd deck?
right now its an old eclipse unit my that my uncle used with his system (the one i have right now)
im think the alpine ixa-100. the mechless one, for use with an ipod. ive been diggin this for a while. its either this one of one of the 9887 or so.. good choice?
should i probably upgrade this next?
thanks
im asking if this is normal? the cd skipping? (i guess my amp isn't clipping)
and if that headunit would be a solid one to go with
if its skipping with the ipod too, then the headunit is not a problem. See the link on how to set gain. Even easier check the amp light and you'll see it goes into protect. If so , then set your gain with a dmm and check the quality of your ground
when i went to the shop, the guy looked at the pretect led, and he said it never came on, so i guess its ok where i set it.
where do i get a dmm? and how do i set it that way?
If its bottoming out on low notes you have shitty subs or you need to turn the gain down. Dont know your setup but alot of low end subs sound great for the most part but for the low lows they ****. Also see what your subsonic filter is set at, should be around 20-25hz depending on your subs.
its and old jl 12w7? i think. it was in a sealed shallow box that fit under the back seat
so yeah its definitely a pretty low end sub.
i duno probably by summer ill upgrade to 2 hdc3 15's and a SAZ 3000d. that might hit some lows right? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
reclessantics
reclessantics
SC
reclessantics
