I have a question about how a amplifier running into full clipping will be pushing ~double power.
I wish I had an oscilloscope scope on me but, once an amplifier clips doesn't the amplitude of that wave stay the same if you keep on turning the volume up. For example using ramdom figures, if an amplifier has 1/8 of the sine wave clipped and the amplitude voltage (amplitude being peak to reference) is 40V, once you turn the gain up on the amplifier would it still be at the 40V I would guess that the more you turn the gain up the voltage should still be at 40V, if the voltage did not stay the same and it increased the amp will still have the same 1/8 clipped.
In order for the amplifier for the amplifier to put out more power, the amplitude must be increased such as your 2000w example, the only way else that 1000w amp can put out more power if it puts out more current. I hope you understand my question. Basically the question I'm asking, if an amplifier runs into clipping how does it increase its power, I sorta considered when the amp is clipping it is sorta at it's zenith meaning thats how much it can put out and that's it.
