what high end sub do you guys think?
And your suggesting the IDMAX 10" while this guy is runnin some nice frontstage in a SUV an doesnt want the bass drowned out. The IDMax 10" is not the driver for this guy...that was obvious. So for his needs, since he was looking at a W7, the Mag seems like a good choice for him.
well that idmax looks good so far! is it worth going with the 12 for the extra sensitivity ... problem is a 12 will take glass work and a ten will not but as i said b4 if its worth it then no problem? can you tell me if there will be a big difference?
Like putting a band-aid on a gun shot wound... Hah.
Flat, with level matched to headunit , ftw. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My sub-bass is flat. Gains are matched. There's still a sub-out control on the HU.
nG
Do YOU have any experience with the IDMAX?
And more importantly... What experience do you have with the Mag?
You got a little butthurt about that, eh?
He ALSO mentioned the Focal driver... and you failed to mention that. BIG difference between a W7 and Focal drivers.
Gamefish, just make sure you go with something that will give you the output you desired. Since you were considering the w7, I gave my recommendations that I believe would be similiar to your tastes.
who makes the mag sub you guys are talking about ? and i want the sub that is going to play the loudest but still falls in that high end sq catagory if that helps
ok what if i ran the mag in the back juiced by the pdx and then like a 8 in a sealed box in the center counsel if i cant fit it then i could run the amp turn on wire on a switch then switch them on or off depending on what im looking for at the time would this be worht the cost of another sub and amp?
gamefish
gamefish
chicago
CBFryman2
Mike Mccabe
