Falloutkid90
So I'm running two kicker amps (4 channel and a mono) I've had this set up for almost a year now.
Today, I'm driving listening to music on the way to work and music cuts off. No sound from the speakers or the subs. I'm thinking maybe the amp turn on wire behind the head unit came lose. After work, I remove the headunit and check the wiring everything is fine. I look see if I blew a fuse, ground came lose, all my wires are tight, but still nothing. I looked to see if the amps were getting power when I turned on the headunit. No power (the light on the amps didnt turn on).
When I installed the system, I didnt want to run two remote turn on wires so I ran the one from the headunit to the 4 ch then tapped into that one and ran it from that amp to my mono.
I dont know what to do any advice?
