How to install 2 powered subwoofers into a 1996 chevy single cab
JiaNaDaRen15
I think I have it figured out but I'm not sure. I want to have a L and R sub-woofer behind my bench seat as well as replace my door speakers and rear speakers. My previous car and aftermarket stereo had an equalizer setting for 2 different sub-woofers labeled subwoofer 1 and subwoofer 2 but I didn't install it so I have no Idea what kind of pre-amp outputs it had, but I'm guessing it had a sub-woofer pre-amp with a L and R output.
My big question is, am I right that I just use a y-splitter RCA connecter and connect one sub to the left output and one sub to the right? And do I just use one power cable for both tubes or do I need to run 2 cables to the battery?
You can run one power wire. Just has to be large enough and split properly. Y splitter is not the best but will work given the output can be matched on the split signal. The output voltage drops when split. What powered subs?
JiaNaDaRen15
JiaNaDaRen15
Fresno, CA
JiaNaDaRen15
