What do you think of this setup?
redphoenix
I have a Lexus SC400. Space is tight. so Small amp, small IB sub, and even 6.5's will be tough to fit.. and price is budgeted.. but what do you guys think?
Pioneer Headunit, not sure which one, but somewhere around 4-5v RCA
DLS CLASSIC CA31 Amp - Link
Elemental Designs 6000s Mids/Tweets - Link
Elemental Designs 11kv.2 Subwoofer Dual 4ohm (Running into 2 ohms) - Link
What do you think of this setup? I may not use the rears, or just wire them off the headunit and fade them.
If you have other suggestions (i recommend) please post them. Im limited by this:
6.5 low mounting dept fronts/tweets
6" mounting dept for 10" IB sub
small area for amp, but i may be able to get away with 2 small amps
im not looking for high DB numbers, i just need a replacement for the speakers.
Thanks
ok... very unhelpful however.
small amp that powers sub and fronts? point me in the right direction
what else would you change? typing mediocre doesnt help me at all.
small area for amp, but i may be able to get away with 2 small amps but i prefer a 3 or 5ch amp
thanks.
if i was you, i would get a good 4 channel amp and bridge the last two channels to your sub. look at the kicker zx line if you are willing to spend upwards of 300 on a single amp... but a cheaper route may be to go with two amps, one for your sub, one for your amp. You don't need much power for that sub.
Are you stuck with buying new or are you willing to buy from ebay/ classifieds?
redphoenix
redphoenix
Florida
redphoenix
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
