what do you guys think of this system
kurrupt
hustlenomics
well all of this would be going into either a bronco or a yukon not sure yet
subs-2 dd9515 d2
sub amp-ddz1a
front stage -2 aq sd8 and 2 earthquake screamer tweeters
front amps-dd c4a for the aq and c1a for the tweeters
all knu wiring
havent decided on a hu yet
and there will be alot of sound deadening in either vehicle.
any suggestions would be awesome
the other idea being thrown around with me and my friends is 2 hdc315-18 on 2 crunch 3000 pros
with matching crunch 2 channels and four channels
you'll need a 300a H/O alt. 4 batts and big 3 upgrade. Do you know how much this is all going to cost you?
i have all the wiring and accesories i need and i also have all the batteries ill need this will be done peice by piece starting with the 9515s then z1a (hopefully used)
should all be done in 2 months tops
also want to run at least dual 300 amp alts because this will be a daily system
kurrupt
hustlenomics
kurrupt
neenah,wi
jeremiah
