what do you all think about this?!??!?
no my amp is 2ohm load, but the way i have it should be about 2ohms if not 1.5 and each pair of subs say 2.1 or 2.0
if u have 4 dual4ohm subs and u got a 1ohm load from them. I would start checking all the coils independently. U got a bad coil somewhere. But to answer the other question if u meant to get a 1ohm load and ur amp is only 2ohm stable after box rise, and all you will be very close to a real 2ohm load prob a good bit higher then 2ohm thus no more issue
If each sub shows 2 ohm then you have subs wired in parallel. There is no way to take 4 2 ohm subs to make a 1 ohm load. This means you have made an error while wiring.
Take some pics of the wiring and perhaps we can spot something you are over looking.
yea that is true bro let me check em out be back in a bit thanks all for the quick input!!//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
nvm it still say two subs are 2ohms im sure im doing it right its not the 1st time doing this.
---------- Post added at 11:42 PM ---------- Previous post was at 11:42 PM ----------
i just did mr. monkey and im wiring them right from the subs terminals
check ur wiring juan...something isnt right with it....also do u have a terminal cup?
05trailblazer
k33p groaning son :)
05trailblazer
Dallas,TX
05trailblazer
