what do u think i should do? i have1 15" seXXX and i wanted to upgrade to 1 more but
Well I will say that 1 Sx with 1225 watts in a 5 cube box at 35 hz is capable of hitting 143 dB, so imagine double the surface area, double the power, and bigger box you are looking at 150+ dB if done right.
Or get 2 regular 15" SE's which will get much louder than what you have now and will be better more of a match for that amp. That, and a bigger enclosure should get you at least 3-4 db. And it won't cost that much more than what you'll get for the sub you have if you sell it.
Getting 2 Se's would actually be a good idea if you don't want to spend the cash on a 2nd amp. They are dual 4 ohm. If you are looking to upgrade amps too then 2 SX's would do awsome. Also you can get the SX as dual 4 ohm (I assume) for an extra 25 bucks or so per woofer. Not sure which would perform better with 750 RMS a woofer, the SE's or the SX's.
Finally, you could post some WTB ads for a SeXXX. There have to be a few kickin around. Even call up David, he seems to have lots of stuff from time to time.
Good luck,
Craig G
eddie23452
eddie23452
West Palm Beach, Florida
wj94
slater
    Mar 22, 2025
slater
    Mar 22, 2025
