what do u thing about profile amps
Dont look at max. Look at Rms. If the amp says 300 rms you should go by that. Now some amps might be underrated or overrated but go by the RMS for the ratings
Max power is bascially just turning the bass boost and gain all the way up, and giving it a +10 db test tone and seeing how much voltage it puts out before it blows up, its worth nothing
ok say your amp is 4 ohm stable. you can run a 6 ohm speaker to it 8 ohm, 16ohm. 32ohm. you get the picture. but you have to understand when you go up in ohms your wattage will start to decrease.
I've had good luck with them also. And since they're so cheap if you're worried about "rated power" just buy bigger. I've got a AP1000 rated 160x2RMS to power a pair of REV coaxials. It must be close as the gain only had to be moved 1/8", seriously.
Plays loud and clean and seems pretty well built for a budget amp.
jeremiah
edit me but not ****? ok?
jeremiah
Canton Texas
PepsiFiend69
michigan born
    May 14, 2026
michigan born
    May 14, 2026
