eclipseaudio620
ok if i were to take a 70$ sony xplod and put a hifonics xx goliath on it at 5000 watts x 1 chan. @ 1 Ohm take your best guess at what would happen
Haha sweet.You would tear the fabric of spacetime, causing all of physics to break down and subsequently bringing the universe to a cataclysmic end.
How do you get 1 sony xplod down to 1 ohm?ok if i were to take a 70$ sony xplod and put a hifonics xx goliath on it at 5000 watts x 1 chan. @ 1 Ohm take your best guess at what would happen
great idea i will probly do that and then after ill see if my friend wants to post the carnageHaha sweet.
I think the cone will XPLOD OFF ZOMG. You should free air it, and play a very low tone to see if you can get the cone to seperate before you burn the coil![]()
it would eventually overheat and die.. slowly, because the goliath does full power into 1 ohm reactive... and the sony is a svc 3.6 ohm coil.. so maybe 1.2kw tops into it..ok if i were to take a 70$ sony xplod and put a hifonics xx goliath on it at 5000 watts x 1 chan. @ 1 Ohm take your best guess at what would happen
