what do u guys think would happen?
You would tear the fabric of spacetime, causing all of physics to break down and subsequently bringing the universe to a cataclysmic end.
Haha sweet.
I think the cone will XPLOD OFF ZOMG. You should free air it, and play a very low tone to see if you can get the cone to seperate before you burn the coil
How do you get 1 sony xplod down to 1 ohm?
Veritas Accumatch ?
but the goliath amp will probably melt the accumatch.
On the other hand, before the accumatch is fried, the Sony xplod cone will probably already be well on it's way to the moon already //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Haha sweet.
great idea i will probly do that and then after ill see if my friend wants to post the carnage
ok if i were to take a 70$ sony xplod and put a hifonics xx goliath on it at 5000 watts x 1 chan. @ 1 Ohm take your best guess at what would happen
it would eventually overheat and die.. slowly, because the goliath does full power into 1 ohm reactive... and the sony is a svc 3.6 ohm coil.. so maybe 1.2kw tops into it..
Loyd L.
Me too and then I have to paddle anywhere I want to go.
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
eclipseaudio620
eclipseaudio620
st louis
bigbassman
