What do I need?
I've got a 2005 Dodge Ram and I'm looking to use either a 10" or 12" Memphis sub under the center section of the front seat and I need to know if I can use a regular depth sub or if I need to purchase the shallow mount sub. I utilize the storage under the backseat so the front seat option works the best.
I haven't purchased the sub yet but I'm running mostly Memphis components and I'd like to use a Memphis sub so please share your recommendations as well.
Thanks,
Michael
you need to forget about the sub brand and find one that works the best with the space that you have. Also does the sub you get work better in a sealed or ported box. I do know that ED has a sub or two that works well in 1 cube ported with a 5 inch mounting depth. Image Dynamics has some subs that work in very small sealed spaces and you could fit two tens or even two 8's. ED also works well in a small sealed box. You can find a box that is premade for you truck and go from there.
JL audio makes the stealth box for that, sounds like ***
Micomoma
Micomoma
Midlothian, Texas
cotjones
BP1Fanatic
BP1Fanatic
