What do I need to support 5kw for daily?
Anonymous
I have an 1100A batt under the hood, the big 3 is done in 2/0awg, I have upgraded my alt to an Iraggi 220A, and I have 2 Stinger SPV35's in the back. Will this be enough to support 2 Cadence ZRS-10's? Main Power and Ground are 0awg. If this is not sufficient than what would i need to add? I do not want my voltage dropping too much. Any input is welcome.
I've got 1 Optima Red Top under the hood, and one Yellow Top in back with the big three in 1/0, and the main run of power wire from front batt to back batt in 4/0:wow: , and 4/0 going from the 2nd batt to the amp. An Excessive Amperage 225 alt. I have a MA HK4000D, and I get a little bit of dimming.
most here have a good idea. imho an extra battery or 2 is a plus when dealing with that much power. the more power you have the more the power it needs swings. double the power double the size of the swing...
I have a Cadence ZRS-9, I don't have any numbers to back it up, but after testing the same sub/box on a few different amps, I'd say the Cadence does what it says it will do.
Anonymous
Anonymous
Cantonment, FL
spoonraker
