What cheap sub should i test?
Those jbls are good. Ive heard them in person. Get loud on very little power
I have 2 of the 10's in my work truck and I am pleasantly pleased with only 250 watts each running them.
Curious to see what 12's can do when really pushed.
Sent from my SM-G950U using Tapatalk
There's a young kid here that needs a new sub and he's getting this one. I know it's probably not the best thing or even close but it makes me wonder.
Sent from my SM-N950U using Tapatalk
as long as hes aint tuned to 33 i bet it POUNDS. probably not very strong under 40 but i bet it would be ****** in a tri port dual chamber box..
I did do some testing on a CT Sounds t1500.1 that my buddy had laying around. It is in that 200$ range that is a common budget. Wired at 0.5 nominal on my 12s.
Sealed legal- 148.6db
Outlaw kick- 150.1db
This is with drop to 12v, with just a pepboys g34 agm up front, so probably comparable to what the target consumer would I have. I'll clamp this weekend, but i can tell you its around 1000-1100w, with reactive about 1.2 or 1.3ohm. Pretty reasonable really. As far as tone burps, no complaints.
I attempted Street Beat testing. This amp would just not play. Protection circuitry appears good however.. various methods of play protected either instantly, or very quickly. So bummed out in that regard. Should be noted at that my reactive is very low, at 49hz where I was attempting to play, it is between 0.9 and 1.0. My rd3250 also protects on SB runs unless track is above 50. My rise is non existant from 44-48hz.
Compared to the rd 3250, Populous 6500
Legal CT 148.6, RD 150.9, 153.0
Kick 150.1, RD 152.1, 154.1
kr15
Polluting Residentials
kr15
California
audiobaun
