What box for hdc318?
ok with aero ports. i have a 8in. do you think a 6cube box with the 8in would work. im not sure what i would need to tune to is the problem. i do a daily driver type comp. no burps. its constant average play. if that info helps. just tryna get a tunning idea
Use the power of the aero brother and get loud its easy to cut volume hard to add start at 7least test then start adding wood inside to cut the volume down til you get optimal score.
i have a blazer so i think im pretty good. im only doing a 46.5 with the slot/lport tho.i figured id be doing alil better then that. but idk. i was thinking my port was a bit big. it was a 8in x 17in lport but i cut it down to 6in. i havnt ran it as 6in yet tho. but idk if it would help much by doin that. but i guess it was worth a try
so start at 7 cubes w/ the aero. and add wood to cut down space in the box. but i still dont know were i should tune
---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
where does your vehicle peak? I would base tuning off of that...
idk. blazers are usually like 37hz i think
Lowflyin
Sit on my face, B*tch
Lowflyin
FU JOSE, PA
bgowdy
