What battery setup for my system?
I'm a bit confused as to what I should use for my battery setup...
Car: 2013 Subaru WRX
- Breathalyzer unit - uses some power
- Cobb Accessport 3 - very little power draw
Under hood:
- DC Power 250a alt
- XS Power D3400
- Big 3 (1/0 gauge in conjunction with stock wiring)
Amps:
- Sundown SCV-2000D (Powering a loaded fi Q)
- Sundown 150.4 (Powering 4x ID CTX65 components - 100-120w each)
Maximum system draw = 2500w
First off I'm not looking to do much listening with the car turned off, so that's not really a concern. I just want to make my electrical system adequate to keep steady voltage while running/driving and maybe just about 10 minutes while off, when waiting for someone to hop in or what have you.
What should I use for my rear battery? Some say I need as by as an XP2000 or a second D3400. Would running an XP2000 pair up with the D3400 or would a second D3400 be worth it?
Others say I may not need any second battery. Considering this I wouldn't mind running the small XP950 just to be safe and have power on tap with no voltage loss. Keeping in mind I believe both of my amps are rated to create max power with 12v, correct me if I'm wrong?
What do y'all think?
That D3400 is enough. Just put one in my friends Tacoma. It's plenty fine, running a modded D2 shredder & CT 125.2 , that's a pretty stout battery.
lyons238
lyons238
Coventry, RI
MrFoca
vegang
vegang
