What are the things that can cause a amplifier to blow
People trying to do things on an amplifier that it isn't designed or built to do. Low impedance, low voltage, bad vibration. Everything else that is listed above. Then the company gets blamed for it.
low voltage, too low of a load
12v isnt low, but below that you are risking it, protection circuits dont always work right so if you are running your 1ohm stable mono amp at .5 dont get pissed when it eventually fails
Crappy design can also cause an amp to go poof. I remember a local shop telling me that 25% of their Soundstream Reference S series blew caps upon first power up! That is what gave them the nickname of Smokestream back in the day.
Also, the Orion HCCA G5 series had an approximate 50% failure rate and was notorious for catching on fire when it did go poof.
I just wanted to throw that out there because not all amplifiers blowing is a result of improper installation.
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
carter1010
carter1010
Charlotte NC
corrie32
    May 18, 2024
    May 16, 2024
