What amp?
ziggyping
13
pa
I have a 12 inch Kenwood shallow mount subwoofer http://www.crutchfield.com/s_113KFCW...12.html?tp=111
in a truck box and I have some tis ebay amp powering it and I don't think I'm getting the right power. Which amp should i get? The sub says 350 watt rms.
I was thinking one of thesehttp://www.crutchfield.com/s_113KAC7204/Kenwood-KAC-7204.html?tp=115
http://www.crutchfield.com/s_113KAC8...4D.html?tp=115
http://www.crutchfield.com/s_113KAC9...4D.html?tp=115
TIS Audio T1802A 1800 Watt 2 Channel Car Audio Amplifier
Bridgeable Amplifier
1800 Watts Power Handling:
1800 Watts x 1 Channel @ 4 Ohm (Bridged)
1200 Watts RMS Power Handling:
600 Watts RMS x 2 Channels @ 2 Ohms (Stereo)
300 Watts RMS x 2 Channels @ 4 Ohms (Stereo)
Full MOSFET Circuitry
Thermal/Short/Overload Protection
Four Internal Cooling Fans
Frequency Response: 20Hz - 20 kHz
Variable Crossovers LPF, FLAT, HPF
50Hz - 250Hz Low Pass Filter
50Hz - 250Hz High Pass Filter
Variable Bass Boost: 0 - 18dB @ 45Hz
THD = >0.05%
Power/Protection LED's
High Level Input (Harness Included)
RCA Line Input and Output
Adjustable Input Sensitivity
Fuse Rating: 25A x 3
Suggested Retail: $299.99
Full Warranty
http://cgi.ebay.com/TIS-1800-Watt-2-Channel-Car-Audio-Amplifier-Sub-Amp-NR_W0QQitemZ120489525532QQcmdZViewItemQQptZCar_Amplifiers?hash=item1c0dbc411c
I don't see why that amp won't power that sub. With 75a worth of fusing it should do around 600 watts bridged (estimate) drawing 75 amps worth of current at 12.8 volts.. Unless one or two of the fuses are dummy fuses and it's actually fused at 25a...lol
Do you have all the filters and the gain set on the amp properly ?
I have 8 gauge going to the capicator and 9 going to the amp (or vise versa) scosche brand lol, and what do you mean set properly? I have the bass bost lpf and gain almost turned all the way up. Do you think its the wireing?
And the proublem, is I don't think its as loud as it should be. I heard it at bestbuy and it was alot louder and sounded better.
So you have everything cranked to the max...lol
It could very easily be the wiring. Try switching around the speaker wires to see if that helps. Also what size is the ground wire ?
Yeah i pretty much have it cranked haha and I'll try that soon and the ground is 9 and 8 gauge too and its grounded to my seat post
ziggyping
ziggyping
pa
Mass Car Audio
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
