What amp should I get???
Sentra4ever
Hey guys I am new to this forum as you all can see. I have a simple inquiry to make in regards to my car audio setup. I currently own two 12 inch JBL subwoofers, and was wondering what would be the most compatible amp for this? I am not trying to go cheap, also I want to consider using this amp in the future. Any ideas? Should i get some thats 2000 watts? or even more? I have 1994 sentra that I want to put this in. If it helps its a in-line 4 cylinder. I was told to get a capacitor to maintain my battery and alternator life. I guess recommended brand names would be good help as well as the recommended wattage to keep it powered sufficiently.
Any feedback is much appreciated.
Don't waste your money on a capacitor.
If you are going to get an amp over ~ 800 Watts RMS, you will need to upgrade your alternator/battery wiring (search for "big 3"), and run big wire to your amp. And with your little car, you may need a high output alternator too. If you buy a big amp but don't do these things, your amplifier won't put out it's rated wattage and you'll waste a bunch of power heating up your little wires.
As thaster said, the more specific you are with what you have, your goals, and what you can spend, the more people here can help you.
yikes upgrade the alternator....I had to replace that already lol... Ok ill get the exact specs of the sub and let you guys know. Thanks for replying.
Okay guys i got more info on the 12 inch JBL's There are 1000 watts each, GT series High performance subwoofer. I can live with getting a weaker amp, i just don't want to have to upgrade my amp or alternator? What's the minimum amp i should get in wattage?
This guy is selling them on craigs list. Would one amp be sufficient sort of like what hes doing? I just dont want anything to break in my car...
http://milwaukee.craigslist.org/ele/1046330269.html
Sentra4ever
Sentra4ever
canada
FarrisAudio
