What Amp should i get for my DB DRIVE SUBS?
taraku
I currently have 2 DB Drive PLT12WD 12''. Im not sure what the specs are because i bought them off a friend. He claims that they are 1000 watt rms each, but i'm not so sure. If anyone could give me details then it would be much appreciated. I'm looking for a good, cheap, and efficient amp to use because money is a little tight.
The DB Platinums are some sick subs! 2k rms a piece. If you want to push these to their wattage limit you're probably going to have to look at an electrical upgrade.
well maybe about 200-300 bucks...i have 0 gauge wires but the amp that i had over heated and blew. If i were to get a amp what should i look for?...im a newbie at understanding amps, but, i can wire any system lol.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
taraku
taraku
Stone Mountain, GA
myjaja
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
