What Amp? Need some opinions....
  • 4
Joshyboy7
Ok....I've got a 12" Kenwood KFC-W303...it's the tornado series sub or whatever...and it's in a medium sealed box. anyways....I want some sort of really clear amp to push it. I'm not looking for something that's gonna wake up the people across the street when i pull in....just something clear that adds more bass to my current setup. So.....doesn't need ALOT of power, needs to be clear, and needs to be less than $200....
Any suggestions?
your best bet would be to get an amp which is rated around 200w RMS - look at JBL, MTX, Rockford Fosgate, JLAudio. these examples will give you a good clean signal for a pretty good price for a 200w amp.
I'm assuming I should be looking at mono amps? Again, I really dont know alot about this stuff....but thanks for the suggestions. Any others would also be appriciated.
-Josh
Once again, I'll recommend the JBL bp600.1. 300 x1 at 4 ohms or 600 x1 at 2 or 1 ohm(s). Got mine from ugonet.com for $187 plus shipping.
849
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Joshyboy7
Joshyboy7
Dallas, TX
imral3
    May 31, 2024
    May 24, 2024
