What amp do I need?
riverpilot
I have a JVC-X250BT receiver 20W RMS X 4 at 4ohms,
six JVC CS-V6948 speakers 60W RMS 4 ohms,
one JL Audio 300W 10W6AE dual 6 ohm voice coil subwoofer.
All I know is that I need a 5-channel amplifier, but I have no idea beyond that.
Can someone give advice on the right amp?
I'd like to run the four speakers through the amp as well as the subwoofer. I was told I need a 5-chaneel amp for that. I start to get confused with the ohms. The four speakers are 4 ohms and the subwoofer is 6 ohms. I don't know if the amp needs to match the speakers ohms or not, and what happens if they don't match.
Budget? Under $400
I'd like to run the four speakers through the amp as well as the subwoofer. I was told I need a 5-chaneel amp for that. I start to get confused with the ohms. The four speakers are 4 ohms and the subwoofer is 6 ohms. I don't know if the amp needs to match the speakers ohms or not, and what happens if they don't match.Budget? Under $400
the speakers are fine they can be ran on any amp ,the sub also can be ran n the amp as well ,you can wire it to 1.5 ohms by wiring both cols together and be fine .i have such an amp for you ,for under your budget new with warranty and shipped if your in the lower states
riverpilot
riverpilot
Astoria
mylows10
