What am I Doing Wrong?!
Heres the controls Im working with
Nope exact same actualy
okay, we can rule that out then.The box seems about right, if your not having any audible issues other then loudness.
one thing to note is that the comps do have higher sensitivity then the DD, two of them will have even more.
what is your gain set to? do your fronts get too loud before the sub reaches a good volume? how did you go about setting it?
Subs forward port forward I assume? Tried any different locations? I had a 2510 in a 1.8cf tuned to 37.5hz running on my 2200d@ 2.5ohm and it got decently loud. I to was kinda upset with its overall performance but this was my fault as my expectations were unrealistic. Nonetheless your going from 24" to 12" no matter the power usually cone area is always king.
Yes!
Sub forward port fires towards the roof
what is your gain set to? do your fronts get too loud before the sub reaches a good volume? how did you go about setting it?Yes!
maybe a gain issue, are you also running an amp on your front speakers? where does your volume control end up when the speakers are too loud? if you post what you have your amps settings at that will help a lot.
maybe a gain issue, are you also running an amp on your front speakers? where does your volume control end up when the speakers are too loud? if you post what you have your amps settings at that will help a lot too.
Not currently but will be soon when my components get here... Im not realy sure what they are at now since I have messed with them so much I think I just left them mostly all at about half sense it hadnt changed anything... and the volume is usualy at about 18/19 on my deck so that its comfortable but Ive turned it up to like 22 and the sub was louder but still not very loud... however at that volume my speakers where much to bright and loud
Bettr n' Revrse
I do what I want
Bettr n' Revrse
Grand Junction, CO
dirtye30
