well rounded system?
hey guys, i went out and bought allot of componets, about 6-7 months ago. I'm looking at instaling it in my 2006 SCREW F150. Im Looking at doing the "Truck Bed Subwoofer Enclosure" only way the it's all going to fit. The good thing is im not home where everything was deliverd to. So i havent got a chance to mess with anyof it untill i educate myself on it all. and what to and not to do.
what ive got.
4 x Rockford Fosgate T215d2's
15" Power Stage 2 Subwoofer
Power Handling:
Peak: 2000 watts
RMS: 1000 watts
i didnt really think about it before i bougt my amps, so i initaly bought
2 X MA Audio HK2000D
2000W Digital Class X Competition Mono Block Amplifier
RMS Power @ 14.4V
750W x 1 @ 4 Ohm
1000W x 1 @ 2 Ohm
1500W x 1 @ 1 Ohm
RMS Power @ 17.0V
1000W x 1 @ 4 Ohm
1500W x 1 @ 2 Ohm
1800W x 1 @ 1 Ohm
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
1 Ohm Mono Stable
After Purching these someone told me that id have better results with these
4x Hifonics BXi 1606D
1-Channel Mono-Block Operation
1100 watts RMS x 1 chan. @ 2 Ohms / 1600 watts RMS x 1 chan. @ 1 Ohm
Super D-Class Topography
Ultra-Fi MOSFET Outputs
Illuminated Hifonics Logo
PMW MOSFET EXVP (Exponential Vari-Power Supply)
SPC Twin Turbo-Torroids with Simpatico Coil Design
Fully Adjustable Accu Cross
Crossover Includes:
24 dB Subsonic Filter (Adjusts 15 Hz - 50 Hz)
Bass Boost: Variable Bass Equalization (+18 dB @ 45 Hz)
Remote Bass Control Included
Balanced Line Inputs with Optional Hifonics MM-BLD-1
Gold RCA Line Outputs
Permits Amplifier Daisy-Chaining
4 Gauge Power Connectors
So i now have both..
there in lies my first question what is going to push my T2's better,
for highs and mids ive bought,
4X Diamond Audio S600A-07 6 1/2 componet sets. (that is 8 6 1/2's, 8 tweeters and 8 crossovers)
specs as follows.
6-1/2" HEX Series Component Speakers System
Power Handling:
Peak: 300 watts
RMS: 150 watts
Proprietary kevlar/nomex hex cone
Butyl rubber surround
1" Aluminum dome tweeter
Ferro fluid cooled neodymium Tweeters
Flat progressive spider with integrated lead wires
Intercooled motor design
4 ohms impedance
Competition grade crossovers
To push my mids and hi's
I've Bought
2x Kicker 08ZX850.4
ZX Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 175 watts x 4 chan.
2 ohms: 215 watts x 4 chan.
Bridged, 4 ohms: 425 watts x 2 chan.
Max power output: 850 watts x 4 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 23-1/4"L x 9-5/8"W x 2-1/8"H
8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
So the questions are,
Will all of this add up to a "well rounded system"? (are the componet sets going to keep up with the 15's?)
What mono amps are going to push my T2's harder? (the HK's or the brutis)
What kind of power plant am i looking at needing to build to keep all this equipment going? (ive heard optima yellow tops, or the Kinetik?)
So you think that the 4 componet sets are going to be able to keep up with the lows? right.
and yea. i was thinking planing on putting 2 6 1/2's and 2 tweeters in each door. the reason that i got 4 sets was, with 4 T2's i thought that i was going to need possibly even more than that to keep up.
So it is good to know that, im looking good as far as being able to talk/scream over the thump of the sub's.
do any of yall, or have any of yall, seen a build log that is anything like what im planning on doing? ive seen one "truck bed sub enclosure" on here though the guy that posted the build log didnt really do anything but before and after pictures.
um,..
and what do yall think is going to be my best bet on the mono amps? i would think, and my thinkin dont count for Jack, because i dont know jack, lol but if i use the brutis amps that is going to be 4 mono's and 2 hi/mid amps with a total of 6 amps.
how do you distribute out signal to 6 different amps?
and another thing, when i say "well Rounded" i mean......
Is all of my gear going to keep up with each other? are the T2's going to drown out the mids/hi's vice versa?
Im on here because i dont know what the heck im doing and hoping to get some educated/experienced knowledge.
Just one set? like i said i dont know much but i dont think that 2 6 1/2 componets are going to keep up with 4 T2's.
when you say "truck bed enclosure" " do you mean doing a blowthrough? As in your going to cut out a hole in your bed and cab and mount the box in the bed?
If so are you going to do that or take it to a shop? An 06 f150 is a pretty nice truck to be chopping up for a system.
Yea, i was planning on doing it myself (the blow threw). ive got a fairly good idea on how i want to do it. ive done allot of metal working in the past it wouldnt be the first thing that ive fabricated of that type. i think that the best way to do it would be similar to what people have done in the past. with the exception of what they used between the bed and cab.
And yea it is a nice truck, 2006 SCREW F150 lariat 4x4. Two tone white and gold.
Yall, share the same opinion as my wife and all my buddies over here. maybee your right and i should just put it all in The Explorer and be done with it.
Everyone has stated that 4 componet sets is over kill. Does that mean that just 2 will keep up?
Yea, that is why i asked, what i should look at as far as a power plant. in thinking that i am going to. have considerd. 4 yellow tops and an aux 230-300 amp alternator. only thing with that is. i think i know that if i was to do that id run them all in parallel. the only question fromt here is where do i pull the power off of that set up do i distribute the charge off the alternator to all four batteries and pull a draw off of all 4 batteries... or,... do i distribute the charge to just 3 batteries and pull the charge off of the last one in the series, or,... do i just hit the first battery in the series with the charge and take my pull off of the last one in the series,.. of cource grounding each battery seperately. directly to the frame, or am i, as i think i am all jacked up, and dont have a **** clue what im talking about.
as far as the parts that i listed out, ive already got them. bought and paid for. so that is more than likely what i am going to use. unless i can find someone to trade with once i get stateside, for something different.
the questions are do i use the HK's or the brutis'es to push my T2's?, how jacked up is my thoughts for a power plant?, and how do i get signal to all those amps in the correct manner?
Like i said before, I dont think that i am going to have any problem at all mounting, fabricating or figuring out how to get everythign where that i want it. im failrly sharp/mechanicaly inclined. though i dont know *anything about Audio. when it comes to wireing it all up. it all makes about as much sence as dual exhaust on a solar powerd car, know what i mean. lol
These are the componet sets and amps that ive already got. Will these work?
specs as follows.
Power Handling:
Peak: 300 watts
RMS: 150 watts
4 ohms impedance
I've Bought
2x Kicker 08ZX850.4
RMS Power Rating:
MOSFET power supply
Skillet_Okie
Skillet_Okie
Ft, Riley, KS
Skillet_Okie
Mike Mccabe
