well, now I need new mids.. :/
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=294-650
I know it says 6.5', but the outer diameter is 7.4". Things are BEASTS. You think those Selenium 6s get loud, you should hear the B&Cs. They are cleaner too.
That would be nice as a dedicated midrange, midbass not so much. Unless that's a typo its got .6mm of xmax. Infinite baffle in a door it would have crap tons out output over 200hz probably, but it's going to run out of excursion and output fast. Long before it will ever mate with his sub. Granted you may not notice the dip between where the sub is lost and where the mids kick in, just depends on acoustics and how critical of a listener you are. Personally I'd go for something slightly less effecient with a bit more xmax if your looking for good extension from the fronts. Probably 92db1w/1m with 6mm+.
Thanks for the in depth post bro.
I mean, I'm not an SQ junkie by any means, if it sounds good & is loud I loves it.
That is my plans. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
J31Rob
CarTune Netwerk
J31Rob
Indiana
BLD 25
