Weird Vas measurment help with LMS.
I chuckled to myself as well when I tried it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I lol'd.
I saw the first hit and was like, wtf? Then it clicked, stupid google.
Reminds me of a Daniel Tosh skit about google, and asian *** ****, lmao.
I'm still running the numbers my friend.
Can you please give me the rest of the specs that you were provided along with the type of driver? I will enter the parameters into my software and try to extrapolate Vas for you.
15'' Dual 4 ohm Car Audio subwoofer
Vas 261.742m ***
Qts 0.530
Qes 0.644
Qms 2.982
Exm 0.606 in
Fs 29.646
BL 10.911T
Erm 0.767
No 1.024%
SPL 89.1 db
Md 100.000g
1500 watts rms
I have more parameters if you need them.
Yes please, I need all the numbers to be as accurate as possible. Especially since it's dual voice coil.
Ok here is all the parameters
Revc 3.600 ohm
Fs 29.646 hz
sd 85.530m sqM
Md 100.00g
BL 10.911T
Qms 2.982
Qes 0.644
Qts 0.530
No 1.025%
Spl 89.1db
Vas 261.742m ***
Cms 251.970u M/N
Krm 11.620m ohm
Erm 0.767
Mms 114.383g
Mmd 100.000m kg
Kxm 65.946m H
Exm 0.606
1500 rms
I came up with a Vas of 261.6 liters or 9.23cu.ft. which sounds about right for a 15" driver with a high Qts. You could probably get away with using this free-air if you wish.
If you care to share the make, model, and purpose of this driver I could help you model an appropriate enclosure. It will be sealed and it will be large. It's mostly dependent on how much power you have at your disposal so that I may ensure that excursion is kept in check.
Please.
Mass Car Audio
Mass Car Audio
Canada
Mass Car Audio
