weird problems with my kicker components
reed dollaz
well first off, ill start with the fade problem. if i fade all the way to the right, the left still plays. same with going to the left, the right still plays. also, when i turn the gain off on my amp, the components still play. isnt it supposed to turn off with the gain set at 0? also, at high(er) volumes, the fuses inside my crossover light up bright red, bad? or normal? thanks.
well. no. i got the 1099 dollar comp set for 350+ shipping. and i doubt that has anything to do with it. the price of something has nothing to with it.
wrong................but yeah the glowing fuses most likely=bad . Check and make sure the RCA cables are actually in the right slots as far as your balance problem.
p.s. fade is from front to back..not left to right and you can turn the gain all the way down and still play music
reed dollaz
reed dollaz
Ocala, FL
bonesninja
