Weird noise
Ummm. broken/loose spiders.... tinsel leads... bent former... something in the box (depending if ported and something got sucked up in there).... loose dustcap.... broken box.... there you go I think i got everybody. might have missed something though
nah ive heard it clip before and this is nothing like it...it more of a object sitting in front the dustcap and as the speaker hits it makes the sounds of hitting something or it backfiring
15" DVC Cerwin vega
watt cadence txa-1000d
jvc head unit
and knukonceptz wiring
It sounds more like a loose dustcap as vehement stated because i took the sub out check it everything was fine checked the wiring make sure everything is connected good reconnnected it and it did it again it sound like the dustcap was loose
how do I fix this
well i put my hand over it to see if holding the dustcap in place would make a difference it didnt its coming from within the speaker but everything looked fine to me
I had a problem last night similar to this. I had a rattling coming from one of my subs (cheap Rockford p210's). Anyway it turned out that the motor was coming loose from the basket. The screws under the spider have loosened up. Take the sub out and carefully pull on the magnet to see if it is separating from the basket. It only takes a small amount of separation to produce a horrible rattle.
ok so i think its bottoming out because i lowered the gain about 1/4 of the way and it stopped will i turned the volume and the gain up back to normal settings and it started again but then i was droving and i let it play at low volumes with my sub off and i turned it back on and it was back to normal wtf?
what could be the cause of bottoming out
too much lil John?
No seriously maybe your suspension loosened up on your sub enough to let the VC hit the back of the magnet. Does it hit almost as hard on less power? something is loose / broken. check your grounds and RCa's. good luck hope you dont need a new sub.
sk8erboyla2004
sk8erboyla2004
La
sk8erboyla2004
