GlowstickNinja
OK, let me give you an overview of the system:
Kinetik KHC1400 Battery
Panasonic cq-8400u HU
Kicker KX1200.1 Mono Amplifier
Kicker L7 12" Subwoofer
Fli Audio 4 channel 900W Amplifier (same as VIBE audio)
4 ohm components if front doors
4 ohm coaxial in rear doors
Wiring:
O gauge from battery positive to Kicker KX1200.1 Mono amplifier
150 AMP ANL fuse 6" from battery terminal
Distribution block inline with 0 gauge going to Kicker KX1200.1
0 gauge ground from Kicker KX1200.1 to body chassis (paint stripped, connection solid)
4 gauge from distribution block to FLI audio 900w 4 Channel Amp
4 gauge ground from FLI audio Amp to chassis(paint stripped, connection solid)
Interconnects:
10 gauge speaker wire from FLI 4 channel to each door
JL Audio RCA's from head unit to Amplifiers opposite side from Power
10 gauge wire from Kicker amp to subwoofer
Problem:
When the FLI 4 channel is powering the door speakers, and the car engine is not running, no problems.
When I start the engine I get cracking and cutout from the amp at med/high volume.
Things I Know:
Kicker mono amp has no distortion/cutout with engine on.
All connections are tight and tidy
Had a kenwood amp before this install, 350W, 2 channel to front speakers, no distortion with/without engine.
Voltage is good, voltmeter shows 14.3 volts even at high volume/subwoofer pounding.
So? What do you think is this issue?
Wiring:
Interconnects:
Problem:
Things I Know:
