Was installing my EQ and something shorted...
SAG3
________
So, I bought a new EQ this morning and I was putting it in. After I wired it up, I was putting it into the dash under the CD player, I guess one of the power connections behind the dash got loose and it starting sparking. It stopped after a couple seconds and now when I try to turn on my CD player and EQ nothing turns on. I checked the radio fuse and it's fine and getting power. But, when i check the 12v acc wire and 12v wire to the battery, they both don't even have 1v going through them. I don't know where or how to start finding the problem... This fukcing sucks............. Is there anywhere that might have been a problem before for others?
This is in a 95 Integra.
get a wire diagram... Check your vehicle fuses... also look at a wire diagram and trace the wire down. Make sure it didnt burn up and die... I would be wiulling to bet its a fuse... you may find some other systems not working as well if this is the case but not always.
SAG3
________
SAG3
Kauai, Hawaii
WantedIsHere
