Wanting ideas of a new box for 3 18" Death Penalties (pic of current setup inside)
46panel
I've thought of selling these to go with something else but then I realize that this equipment has a lot of potential if I can just get it right. I drive a 99 Explorer and have DC 250 alt, 600AH in batteries, two IA 40.1 amps and my three 18" DP's wired to 1.5 ohm. The problem is my box I think, which is very peaky and like 14.5 cubes tuned to 36hz with two 10" ports in a wall behind my rear seats. I metered it and hit 150.0 sealed up on the dash playing music, which I feel is a pretty weak score for the equipment. Thought about doing a bigger ported box but with how much power I have, I thought the smaller box would help the subs handle the power of the two 40.1's at .75. I also thought about doing a 4th order, 6-7 cubes sealed 14ish cubes ported, thought about going back to sub up port back, just don't know what to do. I still want to use my back seats, so without using that room I have max dimensions of 41.75" wide by 33.5" high by 32" deep which is about 22 cubes inner dimensions and after sub displacement. Talked to galatic a few times about a 4th order, but just not sure what will be the best. This is a daily driver, that I want to hammer the lows but still put up respectable numbers. I really like the way my setup looks, but should have spent more time tuning before everything, but just looking for some ideas.
Then here is an idea I drew up of a 4th order.
With only 14.5 ft3 that's only 4.84ft3 per sub and the 2 x 10" ports with no flares is nowhere near enough port volume, if you have 22ft3 to work with , why not go with a slotported enclosure 6ft3 per sub and around 250 -280 sq in of port volume tuned between 30-35hz per IA specs, and brace the hell out of it.
This
Would love to have more port area but due to the size of the baffle there is no room.
I cant help with 3 but I can tell you that you need a bigger enclosure. I run 14 cubes for 2 DP 18s and have 200 sq inches of port tuned to 31hz. Does a 153 on the termlab.
Nice, wish mine did lol
46panel
46panel
Michigan
46panel
