I'm in the process of installing a sound system in my 2005 CR-V. I was told about sound deadening so I have been trying to do a bit more reading and research on it. I always had the idea and notion that everything would sound good as long as I got decent equipment like amps, speakers, and subs. But then I read from other people that sound deadening is one of the most important things and can really make your system sound a lot better and even make crappy speakers sound better too. So, I guess that I need to sound deaden my car as well now and might as well be doing it the same time while I'm installing my sound system.
I'm on a tight budget and really don't want to be spending much more for my car. So, I'm trying not to spend like $200 or more for sound deadening. A lot of people recommend doing 3 layers but I don't really have the funds for that. Does just doing one layer still make a lot of difference still? I will be using Noico 80 mil. Or is it waste if you don't do multiple layers? (CLD, MLV, CCF) Also, does it still help a significant amount to add double layers if I have extra material of the Noico 80 mil I'm using? I'm thinking of doing doors, trunk and floor. Is there anything else that I should be doing? And if I do add extra layers, which areas should I prioritize and are more important?
https://www.amazon.com/Noico-deadening-automotive-Insulation-dampening/dp/B00URUIKAK/ref=cm_cr_arp_d_product_top?ie=UTF8
