want hairtrick install
my single 15" does a OK one. Use to do real good tuned to 30hz im now tuned to 35 and still does it alright
You are cheating. Your sub is sitting in your back seat lol. But still its a nice setup.
I am doing a system in a 2010 camaro currently and we are considering putting and 18 inch BTL in the truck and a huge port firing into the cabin. So if I get it done I will let you know if the hair trick was possible.
More than likely not going to hairtrick a trunk on that single RE. More cone area, think you are bouncing that air around (read murdering your airflow) quite a bit before it hits your windows.
This, sub forward port forward is probably your best bet and thats with it tuned low say around 30 or lower. I had a FI Q 18 in a hatch tuned to 30 and could barely do one off 2k but this is because the sub and port were both back
**** 18th though? lol too big for me and my car
Your best bet is a couple hccas on 6k tuned low with BIG ports. They move a LOT of air/hair
**** i got a lot of work to do. 6k? my current set up does 1500rms. would definitely need a couple more amps
whats the vehicle your doing this in.
lexus gs300 (sedan)
not necessarily nore is a ton of power necessary
so all cone area?
lexus gs300 (sedan)
so all cone area?
No the box design has quite a bit to do with it I would try subs forward port side and I bet you can fit a pair of 12's I fit a pair in an acura tl trunk.
robertoyoung08
robertoyoung08
bay area, ca
robertoyoung08
