Wanna make my car faster...what to do/buy?
Ummm... Unless you have a ridiculous budget, forget turbocharging or doing Nos. Those installs are $4-$5k+ just in parts, and the labor is ridiculous, and it's probably not something you want to do yourself.
LMFAO.. Nos is like 400-600$ for a kit.. but I wouldn't recommend it on your engine..Nos is like a really good bang for the buck, the fastest/easiest way to get HP, but also very dangerous and could damage your engine. As for a turbokit, I'm not sure they have any for the Malibu. If your looking for some performance mods, I would go Intake/Exhaust/Headers. These are probally some of the most major mods you will beable to do to your car since Malibus don't have much of a aftermarket.. Although you could gain a good 30-45hp of them.. I will look around and see if I can find a turbo kit for your car. If you are wanting a car with more aftermarket options, I suggest selling it and looking into a Honda/Acura.. but thats my opinon.. then again.. everyone has a honda/acura..
The exhaust is the muffler(s), and the pipes and headers from your engine to the back of your car.As far as the first 1500, i'd personaly get a nice air intake and a new dual exhaust kit, it will sound clean and 'hollow' and if you want better mpg, just use plus gas, you can really tell the difference, at least in a '98 xplorer //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll vouch for the gas increase... 5mpg gain for a 98 escort.
20 bucks @ regular to fill the tank ($2 a gallon)
22 bucks @ premium to fiill the tank (2.2 a gallon)
10% increase in price.
Now, 25mpg on regular, to 30 mpg on premium... 5 mpg gain.
20% increase in mpg.
On performance: Have you considered getting your engine bored out to a higher displacement? Labor + new parts might run 2-4 grand, depending on how complex that chevy is.
My friend with a maliu fed it the right gas, octane booster, and let it breath (intake/exhaust) and it had "go" juice when he needed!
ok,so I guess supercharging is outta the question...almost 5 Gs...
newb alert! unknown term
1. rip out the a/c, the compressor all the guts, that extra pulley ***** away power even when off2. lighten everything, all the useless interior stuff, body panels seats, whatever you want out
...I'm not that worried about going fatser
look for a shift kit
OK, basically I guess I'm just looking for someone to tell me what to do...like "buy _this_ specific air intake, _this_, and _this_". I still have a lot more learning to do since I'm not able to discern between what criteria would help me out in making a selection. Maybe I should ask again in about a year or so?
Your current engine has a Bore of 3.5" and a stroke of 3.3" ... This means the piston is 3.5" in diameter and it moves up and down 3.3" ... This is comparable to a subwoofer, where bore is diameter of the subwoofer and stroke is the amount of excursion ...
ahh, nice way to put it. I'm a numbers person so that really helped. so does that mean that the 3.1L spec of the engine is the displacement? cause I thought 3.1L was the volume that the 6 cylinders take up (3.1/6 per cylinder). so does the bore & stroke of the piston take up the full volume of the cylinder?
one thing I don't get is if the bore & stroke are higher, then doesn't that mean it takes more fuel & air to push the piston since it's trying to push a larger area of space?
wow, that ram intake air thing...20 bucks...now you're talking...any bad things about it?
Save the money your thinking about putting into, then sell your car. Thats the best bet for you. Then take that money and look for a older, 94-96 integra, honda, 3000gt, etc, parts are much cheaper and you will have many more options to play around with. Why dump alot of money into something like that when you wont have the resale. At least you could sell one of the other cars modded up and get some cash back.
Yes... you will have to replace all of your valves, maybe the rocker arms, and the heads. This will allow for the extra fuel/air intake. "Overhaul" or "Big Bore" kits should come with all the needed parts (except maybe the heads).
4 valves or perhaps 2 oversized valves would be best.
Keep in mind, this isn't something that you and a couple friends can do in your garage (unless you have a motherf!cking good drill press and 2 ton crane) with hand tools.
It will, however, give you much better and solid gains (no maybe about it!) over any bolt on accessory. (not that they aren't important)
I know a guy who makes a few trips a year to Dubai in the UAE (United Arab Eramites) and they, according to him anyway sell stock supercharged Luminas/Malibus. You might look for such an item torn off of one of these... Another thing he's quite fond of is the twin turbo Toyota Camry. And the Nissan Skyline.
For the 3100 ( i have same engine) you can buy The underdrive pully which would add ~5-10hp, cold air intake, ~5hp, exhaust ~10hp All that would cost about $500. A 3400 top end swap would add about 8-10hp and cost about $500 or so. Then get some decent rubber.
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
8
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
547
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
950
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
785
sumone
sumone
Midwest
ttsquared100
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
