jadon087
The Snowman
Okay guys i want to go with an active setup for my frontstage setup because of the great reviews and money that can be saved instead of running 2 passive sets. I wanna do the full frontstage which includes all 4 doors of a ford explorer either 6.5 or 7 inch. I will deaden them with rammat too.
my amp would be Memphis MCA5004 specs:
# Full MOSFET Design
# Built-In Fully Variable High/Low Pass Crossovers
# User Selectable 12dB or 18dB Per Octave Crossover Slope
# RCA Bypass Output
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# 4-Channel MClass Series Amplifier
# Aluminum Chassis with Custon Black Pearl Finish
# Gold Plated RCA Connectors
# Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
# 4-Way Protection Circuitry
# Optional Wired Remote Gain Control
# Adjustable Input Sensitivity: 250mV - 5V
# Dimensions: 25.81" L x 7.6" W x 2.4" H
# Number of Channels 4
# RMS Power (4 ohms) 125 watts x 4 chan.
# RMS Power (2 ohms) 250 watts x 4 chan.
# Total RMS Power @ 2 ohms: 1000 Watts
# Min. Impedance Unbridged 2 ohms
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 0.03%
# Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
# Signal-to-Noise Ratio 92 dB
# Fuse Rating 30A x 3
First question is could you recommend mids and tweets wanna keep it under 500 or so for all 4 doors. i did search and saw the Peerless exclusive 7 inch and seas neo alum tweets 1 inch were the most highly recommended so thats probably what i will go for, unless there are any other suggestion.
Another question i have is can i go active off a carputer in dash or would i need to buy active crossovers, or could i use the x overs from the amp? Also if i need to buy an x-over r there any recommendations?
Thanks in advance and hopefully i wont get flamed because i have said something wrong or not been specific enough.
# RCA Bypass Output
