Wanna Go 3-Way Active? FS: Alpine CDA-9813 & CDA-9853!!
$LICK CALIFA$
2 Decks for sale:
Alpine CDA-9813 - 6-Channel Digital Time Correction, 6-Position Digital Crossover with Adjustable Slope, 5-band Digital Parametric EQ, 27 watts rms x 4, and more check specs.
Alpine CDA-9853 - 6-Channel Digital Time Correction, 6-Position Digital Crossover with Adjustable Slope, 5-band digital parametric EQ or a 7-band graphic EQ, Glide Touch Bar, and more check specs.
CDA-9813 - Comes with face, unit, harness, remote, cage
*Plays excellent, no buttons stick and everything lights up although when the face closes from either a screen tilt or after inserting a cd, there is a slight noise but it closes every time no problem. Its not really that bad but just thought I'd make it known.
-EDIT- I will also add another 9813 unit free that closes perfectly but it doesn't play cd's and no sound comes thru the harness, not sure about the rca's though; the buyer can use it for parts if they wish. Does not come with harness, cage, remote, or face.
Specs & Manual - Alpine CDA-9813 CD/MP3/WMA Receiver with CD Changer Controls at Crutchfield.com
CDA-9853 - Comes with face, unit, harness, remote, cage
*Plays flawlessly, no scratches on the face, no buttons stick, everything lights up just fine. In the pic w/my username, the display is dim because at night I don't want it too bright, but it can be made brighter.
Specs & Manual - Alpine CDA-9853 CD player with MP3/WMA playback at Crutchfield.com
CDA-9813 - $110 Shipped firm
CDA-9853 - $135 Shipped firm - 9853 Sold to nateberrier
NO TRADES
Included in price
O ok I didnt read the OP again just noticed you mentioned it... The 9813's are pretty much the same as the 9855's without glide touch and bio light right?
The 9813 has 27x4 watts rms while the 9855 has 18x4 watts rms. They both have a 5-band Digital Parametric EQ, but the 9855 also has a 7-band Graphic EQ. Everything else aside from the glide touch and bio-light display and the above mentioned is the same
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
