Wanna Go 3-Way Active? FS: Alpine CDA-9813 & CDA-9853!!
$LICK CALIFA$
2 Decks for sale:
Alpine CDA-9813 - 6-Channel Digital Time Correction, 6-Position Digital Crossover with Adjustable Slope, 5-band Digital Parametric EQ, 27 watts rms x 4, and more check specs.
Alpine CDA-9853 - 6-Channel Digital Time Correction, 6-Position Digital Crossover with Adjustable Slope, 5-band digital parametric EQ or a 7-band graphic EQ, Glide Touch Bar, and more check specs.
CDA-9813 - Comes with face, unit, harness, remote, cage
*Plays excellent, no buttons stick and everything lights up although when the face closes from either a screen tilt or after inserting a cd, there is a slight noise but it closes every time no problem. Its not really that bad but just thought I'd make it known.
-EDIT- I will also add another 9813 unit free that closes perfectly but it doesn't play cd's and no sound comes thru the harness, not sure about the rca's though; the buyer can use it for parts if they wish. Does not come with harness, cage, remote, or face.
Specs & Manual - Alpine CDA-9813 CD/MP3/WMA Receiver with CD Changer Controls at Crutchfield.com
CDA-9853 - Comes with face, unit, harness, remote, cage
*Plays flawlessly, no scratches on the face, no buttons stick, everything lights up just fine. In the pic w/my username, the display is dim because at night I don't want it too bright, but it can be made brighter.
Specs & Manual - Alpine CDA-9853 CD player with MP3/WMA playback at Crutchfield.com
CDA-9813 - $110 Shipped firm
CDA-9853 - $135 Shipped firm - 9853 Sold to nateberrier
NO TRADES
Included in price
i want that 9853, gotta scroung monies together for something extra ha ha
hopefully it'll still be here! Lots of interest but we'll see how it goes
Hmmmmm......
---------- Post added at 12:19 PM ---------- Previous post was at 12:18 PM ----------
Do both the motors work well?
the 9853 is perfect, the 9813 works but its kinda hard to explain but I'll give it a try:
when the face closes into its normal position right at the end, it just makes kind of a slight grinding noise like the gears are rubbing together but like I said it closes perfectly every time without fail. I opened and closed it (adjusting the faceplate angle and inserting cd's) for like a day or two to see if it would give out or anything but both sides of the face close evenly to the hu so if you don't mind the sound its not too much of a biggie
Do you have the AI net cables?
no sir but they can be picked up from ebay for a relatively low price
Added' date='
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
