Wall in my Impala
power-fanatic07
Knockin Doors Down
5,162
Texas
well the last thread got all messed up cause photobucket was ghey about their bandwidth so here is a new one with all the old pics and updated pics.
Still waiting on my 18's from ssackett.
40.1 should be done by next week.
between now and then i'm going to be working on the port above the 18's. I've done some research and found out that PSP or "aero" ports are more efficient than a traditional slot port so i'm thinking of going with 4 6" PSP's instead of the slot.
and no those weren't the same pics of 1/0 on my bed two seperate pics of different wire. ~96 feet in all.
and thats 8 gauge for the subs
thats all for now, probably gonna run the 2+ and 2- from the front batt to the first batt behind the passenger seat today as well
that looks like such a pain in the ass to build. **** that, but im sure it will be louddddd. What will the tuning turn out to be when finished? or are you just gonna kinda wing it and see how it sounds?
all i see is a black chick with her hurrrr did....
lol
should be loud.... u gonna do anything about ur suspension?
lol thats my roomies wife, shes mexican and pretty hot its just the glare on the window.
i'm thinking of putting some coil overs on the front just to level everything out. since i have the batts in front of the wall, there's not any weight in the trunk yet. and when im done the only thing that will be in the trunk is the IA 40.1 and the sundown 125.2
Looks good. What you plan on using to help with weight?
thanks man.
well i have a pretty good idea of the air volume and by using psp's site i'm going with 4 6" flared ports that will be 13" long that will give me a tuning of 35 hz. Hopefully
on a another subject, with only the 40.1 and the 125.2 will i see much voltage drop with my stock alt even having the 2 big ass C&D batts with 3 runs of + and -. I don't think I will but if it doesn't hold up I'll be ordering a DC power alt. we will see
lol
That wasn't you in the background Monty?? //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
867
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
Turbodan
Brendon Jenness
    May 8, 2024
    May 8, 2024
