Wall Build *Help*
Winter_C
Teh Pinto Driver
Building Wall in 1974 Ford Pinto...but there is a catch
I am not using any of the hatch space, going strictly back seat...and i can make it work, going to build two seperate boxes, each is only like 4.2-4.5 cubes...so rather small wall...but here comes questions
Ok for starters, putting (4) 12" Rockford P3's in it, going to run 1 kicker kx1200 for now....(looking for another, with no luck)
But i am building wedge boxes because my headrest on my front seat will hit if i build straight up, so i am thinking this, which is where i am confused
If i do two wedges, each have following dimensions:
Height- 15
Width- 38 or 39
Depth on top-10ish?
Depth on bottom- 14.5
Ok...is the wedge with those measurements going to be too angle, dont want sub to hit bottom? should i altar the box? i just need to make sure my seats dont hit...car is drivin few times a week, not strictly SPL car
And, can someone tell me what to use for ports? thinking aeros, but dont know how many or anything
IMO just build one box for all subs,and you can gain a bit more cu.ft.which means you can build one box exactly how you need and not worry about making two seperate boxes.also i think it will be easier to port and tune one box than multiple boxes,but thats just me.
Winter_C
Teh Pinto Driver
Winter_C
Mitchell, SD
91caprice
