volvo alternator or extra battery. help
crunch5868
I just bought the aq2200D and i either need a new alt or another battery in the back. I would rather an alt but i have looked everywhere and cant find one, if anyone knows where or how to get a 200amp + alt for a volvo id really appreciate it. Plan b is the extra battery, do i just get one like a yellowtop or odyssey and do i need an isolator?
no thanks but i am actually looking at the HC600 now. im not going overboard on this only because I am on a budget but do you think a 2nd yellowtop or HC600 could push the aq2200D?
The aq2200d dose have a small footprint but i would go with alt and a batt and big 3
there are usually small companies that can take your pre existing alt and beef it up for like 100-200 dollars, but when they do that it usually doesn't charge at idle... or charges very little...
I called around to different companies online seeing if they could make a custom one to fit and then one guy told me that they dont make aftermarket ones at all for my volvo which makes sense after all the failed searching ive done. Seemed like a good company and we agreed that the universal alternator is pretty close to my stock one. Here it is its 105 amps at idle and 220 at 1200rpm and up. Will that be enough? heres the universal one: http://www.powerbastards.com/default.asp
universal :
my stock:
crunch5868
crunch5868
413, Massachusetts
crunch5868
BP1Fanatic
BP1Fanatic
