Volts drop to 11 and under randomly.
haloplayha
So yesterday cruising town listening to some music my headlights dimmed and I checked my gauge and noticed the voltage dropped to almost 9 volts. I killed the truck and cruised it into a parking lot. I took my amp wire off and it seems to be just fine without it. I bought a new battery and alternator so I can somewhat rule those out. I can idle with my amp hooked up and blaring it without voltage drop but if I was to go down the road, sooner or later it would nose dive near 10-11 volts but a second or two later it would rise back up to 14 volts. I've looked it over but I don't know what's going on and it's driving me crazy! If anyone has any information it would be greatly appreciated!
What amp and subwoofer are you running?
Reason I said fuse holder is a long time ago I randomly started getting bad voltage drops into the 9s and my fuse holder had melted and was causing the bad drop.
Might need a separate wire harness that plugs into your alt and connects to your factory harness. The same thing happened to me when I bought my singer alt. I contacted mike and told him what was happening and he said that was a common problem because the high output alt trips up the cars electrical system (or something along those lines) and could make your volts rise and drop quickly and drastically so I needed a separate wire harness/adapter to keep my volts at a constant number and its been all good since, don't drop below 14v. Mike had said its a common occurrence on some vehicles when you put a HO alt on. That might not even be the issue though just thought I'd let you know what happened with me just in case. The harness was only like $20 bucks by the way
Check your ground and check your fuse holder.
This^^
i had this issue before and wasnt sure what was the issue. Checked the fuse block and the fuse block shorted out. Thats when i stopped using fuses all together lol.
I however never openly tell people not to use fuses or that its the right thing to do. I know the possible consequences of my choice
This^^
#thuglife
There are reasons people don't run fuses when competing.
I would like them in my daily vehicle though.
If you get in an accident and your battery bank shorts, you're screwed.
If this is your amp. it looks like there is an input for a bass remote. It looks like the input for an ethernet cable. You have to find a remote...
When you do find a new Ground spot look for something existing that is tapped. If nothing like that is available make sure you cleanthe area to...
13
haloplayha
haloplayha
Stigler, OK
Eggroll
    May 20, 2024
    May 20, 2024
