Voltage
Lucid15
Always open to trades!
My car is a 1995 Eclipse GSX. I read 11.7 volts at my amp without it starting. Then i read about 13.7 when the car is running. I know this is lower than it should be. I have a brand new battery up front and a HC800 connected to the battery, which also powers my amps. I get about a 1.5 volt drop when the bass hits. Does this call for the big 3? My alternator is at the bottom of the **** engine.
13.7 is fine.
and with 2000RMS @ 1 ohm, you definately need to have the big 3 done, and i would recommend more battery/HO alternator.
sorry... i have a new system now. Just a 700 RMS amp goging to a 10" Type R and a little Audiobahn amp powering my comps.
I was about to ask what amp. I would do the big 3 first and foremost. Play your stuff at full tilt and see if you notice your lights dimming on the low notes. With what you have you shouldn't.
13.7 is fine.
Lucid15
Lucid15
Portland,OR
TurdFergueson2
