voltage step up converter
the step up converter or the wire thing that programs the alt for higher voltage. the step up box is only good for like 30-60amps of current so u would need quite a few of them where as the alt wire uses the full potential of the alt but requires a step down for the factory system
im not sure which. i was told this was something i could do. to bump my system up to 14.4 and 16v so i can get the most out of my amp. he said it would be like 300 so I'm assuming its the harness
Why not just upgrade to a better amp? From what ive seen they only do a clean 750wrms @ 1 ohm anywho.... I think a better amp would help more then put that AP on 16V
I had a APSM-1300 on my JBL P1022 @ 1ohm, trust me get a better amp. Money will be better spent
id be getting a lanzar amp and modding it. but my alt can't put out enough power. so if i get a volt step up then i can make an amp put out more power. because even the apsm1300 at 1 ohm on my electrical will only put out aroun 400w.
I have a Turbostart Step Up Transformer that charges 12v batteries at 16v. I charged 4 Turbostart 16v batteries with it running 8k watts. PM me if interested.
im exploring alternative methods of upgrading my electrical. rather than getting a $260 160a h/o alt and a new batt if i need one. $120. so almost $400.
vs
the step up which I'm seeing for under $300 or if i get the step up will i still need a h/o?
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
