Voltage regulator
  • 5
LosIsATool
Is there a way to flash the stock regulator. I got the HO in WITH THE RIGHT PULLEY and I still sit at about 13.5 with the car running. Im dipping into the high 11s at the amp terminals full tilt at roughly 2600 watts at .5ohm at idle. If I can get to 14.4+ I would be perfect in any senerio
what vehicle? some vehicles control voltage through the ECM (think thats right) i read you can bypass this on the newer hondas...but dont know how safe it is to do so
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
530
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
LosIsATool
LosIsATool
Pensacola, Florida
Mitch86
    May 24, 2024
    May 23, 2024
