Voltage question...
  • 2
agarabaghi
So my isolator broke, and now my aux battery is not charging. With the engine off and all the amps im reading 10.9-11.0v sitting. This could cause some issues with the amps and cause clipping right?
Im not running the stereo anymore, but i noticed my sub was cutting in an out, and then i realized the isolator was broken. One of the posts broke off and now it's set to always open (keeps both batteries separated).
Hopefully when the new isolator comes in, and i get the battery charged back up everything will go back to normal.
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
643
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
