Voltage Drops
How would I be able to tell if the amp draws that much current? Is there a particular stat that shows how much current the amp is drawing?
100A continuous is a ridiculous amount of current for any amp unless you're playing test tones at full volume.
A good 1500w class D is going to draw no more than 50A rms to play music LOUD.
4 ga wire with a 100-120A fuse should work fine.
I use an 80A fuse for a 700w class D and 360w class a/b - both amps are under-rated and I've never blown that fuse.
digitalbass
digitalbass
pittsburgh, pa
n2audio
Mike Mccabe
