voicecoil wiring options
my amp says its 400rms @ 4ohm n 600rms @ 2 ohm. does that mean it gives out more power when its connected as 2ohm? if it is, must i go get 2ohm woofers?
so what if u have a dual 2 ohm sub and a mono amp that is stable for 2 ohm and i want it to be 2 ohm the diagrams show a total of 1 ohm and then 4 ohm loads so if i want the amp to have a 2 ohm load then would i buy a 4 ohm speaker that will equall 2 ohm to the amp? i thought u had to match the ohms up and the lower ohms the more bass u will get. so then what combo should i do?
ps> im getting 1 sub and a mono amp.
as for your setup, 2 dvc 4s will equal a 1 or 4 ohm load.
1 dvc 4 =2 ohm load.
the lower ohms, the more "wattage" is available due to less resistance. amps don't put out "bass". the sub does.
yea, i don't see how the charts are that complicated.
seriously dude. it just drives me crazy. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
but i think they all expect us to "spoon feed" them..//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
i was just wondering if i could wire my subs like this :
so i can obtain a 4 ohm load , the subs are in two seperate boxes
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
NorthFramingham
    Jun 30, 2026
