Hmm so say I wanted to make a quarter wave for 2 SA-8s for daily or SPL, how much bigger wud this enclosure be (than a porter box)?Horns are generally louder than normal ported boxes, by t-lines are not. T-lines trade off efficiency for better transient response and a wider bandwidth than ported boxes.
No. Depending on the subs FS could be anywhere from 10-15cu.LOLSo I guess a box like that for two 12s is about the size of a fridge?
Because of the size of the enclosureWow! From what I heard horns and t-lines are more for SQ applications... If they produce so much more power over ported then y don't we see these in more spl applications? I know its been asked before but evener seen a legit str8 forward answer
This is true. Tline's are not suppose to be louder, unless you know where the tuning of the box is and the sub in a transfer setup. Then you have whats called a "one note wonder" that peaks a certain frequency through the roof. Thats why i did 145 with in 3-5hz of each other.Horns are generally louder than normal ported boxes, by t-lines are not. T-lines trade off efficiency for better transient response and a wider bandwidth than ported boxes.
LOL. at least double. would take a few calculations to know exactly.Hmm so say I wanted to make a quarter wave for 2 SA-8s for daily or SPL, how much bigger wud this enclosure be (than a porter box)?
DO IT!Lol time to get a van and throw a 21" warden in a quarter wave folded horn
Wasnt the surround. It was the spider. I used an adire spider from Patrick at Robot Underground. That thing took MASSIVE amounts of abuse before it tore. Think of it as a 2" ww on a 6" spider. Any other spiders would have torn earlier. But this one stood the test of time and i HIGHLY recommend it if building a 2" coiled sub. Im concidering building it the same, but..... My man Chris(zeuslicious) hooked it up with a 2" LMS/LMT coil that is a perfect fit! Im highly concidering using that next. I wont get close to as good of numbers but it will sound sweet! This wasnt a spl build. It was 100% SQ but ended up being loud as fawk anyways!nice!
Just read about the surround tearing. You going to use the same coil & softparts for the re-cone?
DO IT!
Thanks Shane! It's working beautifully! Wish i had 2 of them for more power. Its amazing since its fully unregulated. I could keep feeding it power and it will keep making power till it burns up, but im not looking to abuse it.Nice, I miss that amp. Glad it's working well for you.
