very high powered 2ch. amp?
Nope just like op already shot down DD because spl companys obviously could never make an amplifier of any quality to be used in an SQ install //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
FREQUENCY RESPONSE ; 20Hz ~ 20KHz
SIGNAL TO NOISE RATION ; 105dB
HIGH PASS SELECTOR ; ON / OFF
INPUT SENSITIVITY ; 6V ~ 0.2V
MULTIPLY ; x1 , x 10
CROSSOVER SLOPE ; 24dB/OCT
HIGH PASS FILTER ; 20(200)Hz ~ 500(5K)Hz
LOW PASS SELECTOR ; ON / OFF
MULTIPLY ; x1, x10
LOW PASS FILTER ; 50(500)Hz ~ 500(5K)
Remote control
Line output
0 Gauge Power/ Ground Terminal
2Oz Copper Printed Circuit Board
Burr-Blown OP AMP & High Grade JRC OP AMP
4 Power transformers
Band Pass Filter Capable
When I read sq with pro audio 8's on 1000 watts each I laughed. I just hope I get to see videos of this when its done. I would just like to know how the hell this system is going to be tuned with that many speakers playing the same frequency...
FREQUENCY RESPONSE ; 20Hz ~ 20KHzSIGNAL TO NOISE RATION ; 105dB
MULTIPLY ; x1, x10
Remote control
Line output
Sarcasm bro sarcasm
I was just being a smartazz , quality is quality
again... i can build hifi towers. design passive crossovers and actually build a speaker. here's the deal... i came here asking for info on a high powered 2ch or 1ch monoblock full range amp. i didnt need your opinion(s) concerning the thought process of my design. go that? it was very simple. this guy right here, the "OP", the "THREAD STARTER"... asked a very simple recommendation. nothing else, nothing more. if you cant actually contribute to this thread with useful information.... then gtfo.
Since OP has not a clue perhaps he should GTFO....
I run a bunch of PA mids, so I know it can be tuned and made to sound good. Active HU and a TON of amps is what worked for me. Imaging/staging are impossible with that many speakers, but the main goal was to keep up with LOUD bass and be musical at lower volumes. I would not call it SQ by any means.
In the past I've run the mids in a pseudo 2.5way and that worked pretty well also, just took some time to dial in xover points/slopes
ok... im torn between the dd and american bass monster 2 ch's. i was dead wrong about DD. sorry about that. the pa drivers are going out the window. im strongly leaning toward the seas W18NX. run two per door on a 4ohm load. wish they made those drivers in 4ohm.
vain mccain
vain mccain
atlanta
mlstrass
vegang
vegang
